Volumio: 3.175
Spotify Connect2 plugin: 3.0.7
Spotify on my macbook doesn’t want to connect to Volumio. I can see it on the list but nothing happens when I click on it. It works fine when using Spotify connect to Volumio from my iPhone.
Here is the log when failing to connect from my mac:
Starting Live Log...
[Vollibrespot] : Connecting to AP "ap-gew1.spotify.com:443"
[Vollibrespot] : Authenticated as "1135114041" !
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Event: Volume { volume_to_mixer: 21626 }
[Vollibrespot] : Country: "GB"
[SpotifyConnect] 32.99916075379568
[SpotifyConnect] Volume: Spotify:32.99916075379568 Volumio: 33
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: SessionActive { became_active_at: 1640165592053 }
[Vollibrespot] : SessionActive!
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 296270071491791382650575278370571289151, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 296270071491791382650575278370571289151, audio_type: Track } }
[SpotifyConnect] A connect session has begun
[SpotifyConnect] Device palyback is active!
[SpotifyConnect] Currently active: volspotconnect2
[SpotifyConnect] Not requsting volumioStop on our own service
[SpotifyConnect] Vollibrespot Active
[SpotifyConnect] Pushing new state :: true
[Vollibrespot] : Autoplay uri resolved to <"spotify:station:playlist:48ISxNHIzuAL1ubjUmE61q">
[Vollibrespot] : Resolving uri "spotify:station:playlist:48ISxNHIzuAL1ubjUmE61q"
[Vollibrespot] : error 403 for uri hm://keymaster/token/authenticated?client_id=4ced2e7c73484127be5d36015752eb43&scope=streaming,user-read-playback-state,user-modify-playback-state,user-read-currently-playing,user-read-private
[Vollibrespot] : Error: MercuryError
thread 'main' panicked at 'cannot poll Map twice', /build/cache/registry/src/github.com-1ecc6299db9ec823/futures-0.1.31/src/future/map.rs:35:29
stack backtrace:
0: 0x9b6040 - std::backtrace_rs::backtrace::libunwind::trace::h4e6fc6cdc5d76862
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/../../backtrace/src/backtrace/libunwind.rs:90:5
1: 0x9b6040 - std::backtrace_rs::backtrace::trace_unsynchronized::h1c665adaaf480d86
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
2: 0x9b6040 - std::sys_common::backtrace::_print_fmt::h39ff02745027e048
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:67:5
3: 0x9b6040 - ::fmt::hc83ae421f857c6ae
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:46:22
4: 0x9d76a4 - core::fmt::write::h59f33d28fc1a9cf5
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/fmt/mod.rs:1092:17
5: 0x9aefec - std::io::Write::write_fmt::h96774110acd52d88
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/io/mod.rs:1572:15
6: 0x9b874c - std::sys_common::backtrace::_print::h28b9431057012c44
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:49:5
7: 0x9b874c - std::sys_common::backtrace::print::h28173b7ebfe4a4ac
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:36:9
8: 0x9b874c - std::panicking::default_hook::{{closure}}::h12f82aa3def34336
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:208:50
9: 0x9b812c - std::panicking::default_hook::hee29440c29c1cc2e
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:225:9
10: 0x9b8dac - std::panicking::rust_panic_with_hook::he7d3b6e3eee77e72
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:591:17
11: 0x9b8928 - std::panicking::begin_panic_handler::{{closure}}::h7faba6b3632756a6
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:497:13
12: 0x9b65bc - std::sys_common::backtrace::__rust_end_short_backtrace::hdde0f982a7a71ce9
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/sys_common/backtrace.rs:141:18
13: 0x9b8870 - rust_begin_unwind
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:493:5
14: 0x49221c - core::panicking::panic_fmt::h97b6949f75a63095
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/panicking.rs:92:14
15: 0x4920a4 - core::option::expect_failed::h4183cd8fa1675d39
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/option.rs:1321:5
16: 0x6a7944 - as futures::future::Future>::poll::hb0ddb0e74a1baa46
17: 0x5741a0 - ::poll::h1a955c132b92df14
18: 0x4b5b04 - ::poll::h19799562239aa72c
19: 0x4d20a0 - futures::task_impl::std::set::h0ef71bfab756f27d
20: 0x4ec7b8 - std::thread::local::LocalKey::with::hb3c749d82f06f5c0
21: 0x4c4710 - tokio_current_thread::Entered
::block_on::hac3e29a0a4da8120
22: 0x4ec178 - std::thread::local::LocalKey::with::h78cb87ff6f4c2b7d
23: 0x501cd4 - tokio_timer::clock::clock::with_default::hb0853b95f60f0630
24: 0x4be9f4 - tokio::runtime::current_thread::runtime::Runtime::block_on::h239cb8d546240575
25: 0x4b8258 - vollibrespot::main::hf11cedd7d8a3be51
26: 0x4eb500 - std::sys_common::backtrace::__rust_begin_short_backtrace::ha48b0377a890cb6d
27: 0x4eb720 - std::rt::lang_start::{{closure}}::h120c4b14d2445a8e
28: 0x9b9198 - core::ops::function::impls:: for &F>::call_once::hb7f0eab2b8615017
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/core/src/ops/function.rs:259:13
29: 0x9b9198 - std::panicking::try::do_call::h2c625414401a1a99
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:379:40
30: 0x9b9198 - std::panicking::try::h09167d835e285a07
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panicking.rs:343:19
31: 0x9b9198 - std::panic::catch_unwind::hdff19ee37d8421eb
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/panic.rs:431:14
32: 0x9b9198 - std::rt::lang_start_internal::h835544f25e1ef31c
at /rustc/9bc8c42bb2f19e745a63f3445f1ac248fb015e53/library/std/src/rt.rs:51:25
33: 0x4b9a08 - main
34: 0xb6bfc718 - __libc_start_main
[Vollibrespot] : EventSender disconnected
[SpotifyConnect] Device palyback is inactive
[SpotifyConnect] Device Session is_active: true
[SpotifyConnect] Sink released
volspotconnect2.service: Main process exited, code=exited, status=101/n/a
volspotconnect2.service: Failed with result 'exit-code'.
volspotconnect2.service: Service RestartSec=2s expired, scheduling restart.
volspotconnect2.service: Scheduled restart job, restart counter is at 3.
Stopped Volspotconnect2 Daemon.
Started Volspotconnect2 Daemon.
vollibrespot v0.2.3 769ce77 2021-06-04 (librespot 08d8bcc 2020-10-07) -- Built On 2021-06-04
Reading Config from "volspotify.toml"
[Vollibrespot] : Using Alsa backend with device: volumio
[Vollibrespot] : Failed to register IPv6 receiver: Os { code: 19, kind: Other, message: "No such device" }
error: error
