Greetings,
I’ve been using spotify connect2 and I noticed that from the android app I can only see the device if turned off multi-user device and I logged in. If multi-user device is turned on, I can only see the device in the spotify desktop app.
Though if I first connect from the desktop app, I can also see it in the android app.
Another issue is that sometimes I hear no audio even though the progress bar shows like it’s playing the track.
Issue 1:
Can you check if the Spotify mdns broadcast is up and running fine in your network? An easy was is by installing a Zeroconfig browser and check if you have the _Volumio and _Spotify-Connect services visible?
It does solve the issue, but after a reboot the file is overwritten.
EDIT: as for the second issue, it seems that it loads the track successfully, but if I change tracks rapidly, it takes a longer while to start playback. The developer is aware of this issue.
Seeking is indeed much faster in the new unreleased version - along with a few other improvements as well (direct volume control, better integration with the Volumio UI, Spotify radio, etc), we should get around releasing it soon…
