Hallo all together,
I have a Problem with Spotify. I am not able to get Sound Output while playing Songs with Spotify.
Internetradio works fine.
I am using a Odroid C1+ with the official Hifi shield (DAC) from Hardkernel and Volumio Version 0.976.
Attached you will find my spop.conf, maybe some Parameter is wrong.
I hope you can help me.
Marcel
spop.conf.zip (1.68 KB)
balbuze
September 12, 2016, 6:41pm
2
hello,
Your file does not look like the one generated by the plugin… How did you install it ?
You’ve got no sound probably because in sox section there is nothing after “output_name =”
You should have something like
output_name = hw:0
To check the output to be used, enter
aplay -l
Hello balbuze,
Thank you for your answer.
I have installed Spotify with the Webinterface of Volumio as a Plugin.
To connect to my Spotify Premium Account I have changed Username an Password directly in the spop.conf.
I have changed to “output_name = “ just to test. But with hw:0 it did not work too.
I will check aplay -l tomorrow and let you know if I have success.
balbuze
September 13, 2016, 6:28am
4
Why don’t you use the webUi to configure the plugin? It should set the right parameters
