Can not play Spotify. Spotify gives: Spotify API error. That is a pitty…
Spotify trouble again…
The same with newest volumio update … I checked /etc/hosts and it has some spotify servers, but it is not working, only I can browse albums
Do you have installed v3.0.6 of the Spotify plugin?
Yes 3.0.6 I started with that version of plugin, earlier I did not used the spotify plugin. All lists are stalled, I can see them but cannot play or even start playing.
Hi Piotr,
I am sorry it won’t help you to hear it is working fine for me.
I guess you already restarted Volumio and tried after that.
Maybe uninstalling, rebooting and reinstalling could help.
Best Regards
Josef
hi, unfortunately i have the same problem 3.06 latest volumio version. I can register premium, see the albums. But it can’t start
Other audio sources work. When I click on the time spotify api error comes up. Maybe someone has an idea? Thanks
+1
I have followed the advice in other threads, but still getting the Spotify API Error: Not found
I see the artwork and the timeline moves forward a few seconds, but no audio and it just pauses again.
I am pretty sure that it was working untl a week ago.
I have api error too. Reinstalling does not help. Version 3.0.7
Same here using the Spotify plugin 3.09. I think it worked better with the previous version, but haven’t tested it extensively enough.
I have the same bug…
Has anyone managed to fix this?
