It is just as the title suggests. I noticed that when connected Volumio through Spotify connect everything works perfectly minus the built-in AI DJ. I’ve tried from multiple devices and I’m always given the message “Something went wrong. Try again in a little while.”
Has it worked before? I use Connect with my Nuvo multi-room setup and the AI dj doesn’t work there, either. I think it may be an issue with Connect.
After testing with a few other devices it does seem to be an issue on Spotify’s end.
