I installed volspotconnect 2 to volumio 2.389.
Although it was able to be played in the previous spotify 1.0.80.474, after updating to the latest version (1.0.82.447)
spotify recognizes volumio as a device but can not play it.
If changed the spotify version back to 1.0.80474, playback was possible.
Dear developer
Is there an update plan for volspotconnect 2?
Yes a new official version is coming. By waiting, you can install the dev version github.com/balbuze/volumio-plug … otconnect2
Hello balbuze,
Thank you for the information
I will try dev version later.
Best Regards,
Volumio Spotify Connect 2 Device connection (playback) was possible from Sotify ver 1.0.82.447 after installing dev version 0.7.5.
I will report that.
thanks!
