Speaker noise in standby
my setup is a raspberry 3 with a suptronics x400 DAC.
In the sleeping room I heard a noise - finally I figured out that it comes from the speakers.
Should volumio mute the speakers when no playlist is played :confused:
Or other question - do you have this troubles also with other dacs?
I have a hardware tuner for presetting the volume. and when it is set to 50% I clearly can hear this noise in standby mode,…
GreeT`s eRich
I think that it is a board issue. As your board does power conversion, D/A conversion and amplification, I guess somewhere it picks up some static noise that get amplified even when the Pi is not providing an I2S signal.
Easiest way to test I think is to turn on your Pi without the SD card so it doesn’t boot anything. If than you already hear the noise, it is not the Pi.
Verzonden vanaf mijn iPhone met Tapatalk
I agree with PatrickB. I own this board, and I would add that it’s sensitive to the electrical environment. Power cable near the board may cause this.
Take care the power supply cable does not touch the board.
