I’m testing volumio (3.616) and activated at commandline the internal snapserver and set snapfifo in mpd.conf to enabled. Everything works fine, but the sound is horrible when I connect from other snapclients to voluminos snapserver.
The snapclient is ok, it works fine with another spapserver.
I tested volumio on a raspberry and also on x86 … same result.
What is making the sound streamed by volumio snapserver so horrible?
