I have a pleasure to inform that together with the new Volumio release also dedicated Android Application has been released to control Volumio and give multirooms functionality.
In the App called Sound@home you will find:
UI for simple management
Control up to 5 rooms
Player with full comands, volume, progress bar, name song etc.
Playlist full management (Add/remove/play)
Database Full Management (Add/add and Play/Update)
Add/remove NAS for one or all rooms
WebRadio Playing
WebRadio Add/Remove
Automatic configuration of Volumio devices
That sounds great but unfortunately it was not available for my phone which is a Samsung Galaxy S2 (GT-I9100). Samsung sold loads of those phones so I believe I am not the only volumio user with that phone. If it could be made available for my phone that would be great!
I just updated new version 1.1beta.
Now all the devices (except KitKat OS) should be supported.
KitKat has introduced big changes on menu so I need to make dedicated changes for new KitKat OS.
Please let me know if you have some problem, I will try to feedback as soon as possible
Would it be technically possible to consider a web app? I appreciate your concern for open software and it’s not unlikely that Apple would refuse the app, but a web app could perhaps work…
First I want to say, that sound@home is great…thanks a lot
However maybee you can change the Volume bar.
There is just in the top of the bar the possibility to change the volume.
__
| loud
| off
But maybee I made a mistake !!?
On Nexus S sound@home crashes often.
I will sent reports.
@Erl:
Hi Erl,
thanks for your comment.
About the Volume bar you are right. Unfortunately the bar is just sending the volume value to be set [ from 0(bottom) to 100 (top)] to the Volumio but it seems this is the current behaviour. So I’m thinking to use a non linear function like for example below:
But I need to make some check and attempts and I want also to check this with Michelangelo if something can be fixed on Volumio side (but I know he is fully working on other fixes ).
Yes please send reports of Nexus S and I will check them to understand what’s happening (we are in beta version and I hope to have time to implement and fix all your suggestion/comments).
