I don’t know what’s going on - I have a problem that my volumio stops playing after a while.
setup:
Mostly using spotify connect - via volspotconnect2 (latest version)
Output via Allo DigiOne
v 2.233
After the sound stops only thing to help is to reboot.
In the log i tried playing a single flac after the sound disappeared, but nothing else worked. Airplay didnt work etiher, and the player wouldnt player anything than that single song ONCE…
Before this latest reboot, it stopped sound on a webradio.
I see in log alot of : radio volumio[1036]: Wrong scontrol identifier:
1- You’re using a devevelopment version, which can be really unstable. Please use the special version for digione and not this one
2- The issue can be due to spotify connect also, which is still a bit unstable
hi
i have the same problem with official VERSION: 2.246
i use raspberry PI 2 with allo DIGiONE
after a couple of tracks no more sound. ( seem like the raspberry bug and nothing more work. i have to reboot )
the first time i used digione i had a lot of crack sound in the background.
i used and external hardrive 3"1/2 with 3 partitions. ( volumio is very slow to detect the 3 partitions on the external hard drive on USB. 30 min to detect the 3 partitions )
i decided to use my small 2"1/2 hardrive ( 1 partition ) and the sound do not stop after couple of tracks playing.
You definetely have a power problem there: the pi is not able to feed that hard drive and the digione at the same time. Use a powered USB hub to connect your hard drive
