Be able to sort the tidal “track” list
Coming next week ![]()
ok half way there. It does sort the list according to date and name. When sorted by date you cannot play any song. Sorted by name it works but with the old problem that when you click a song it plays some other from down the list
I updated to latest alpha today (just in case it resolves the issue). The good thing that thing works when reverse sorted with date for about half my entries, which makes it usable. For the last half of the entries it selects a certain song many songs below. However it doesn’t work when is normally listed.
Reverse similar behavior in A-Z sorting. It works for half but for normal sorting.
BTW I have a small impression that Tidal Connect sounds a little better than native but maybe its just an impression
bumpy?
I am in development stream updating… Problem is worse…
Replied also to other thread. To fix this just remove any greyed items/songs from the tracks list and everything comes ok
