I’ve the last version (2.555) on raspberry 3 with hifiberry digi+ pro card.
When I want to listen webradios (on the volumio selection list for example), some strange thinks happen.
Some times, audiophile jazz plays … others times don’t
Some webradios never plays (absolut radio for example) … volumio seems to be down : nothing plays (qobuz for example)
Back to audiophile jazz radio … it’s ok !
Switch to bbc radio 1 … it’s ok !
Switch to absolut radio … volumio plays nothing !
switch to audiophile jazz … nothing !
switch to qobuz … nothing !
back to the main page, I click on play button … it’s plays audiophile jazz radio …
Any idea ?
Firstly, is this behaviour only occurring with the last version of Volumio that you tried? Is there any pattern as to what plays and what does not? Have you changed any of the stream urls?
You could check the system logs … see here. Reboot your system, try a series of radio stations noting which ones work and which don’t. Send your system log, and hopefully there might be some clues in there.
hi,
many thanks for help
all this radios are in the volumio selection list
#1/ fresh new start
logs.volumio.org/volumio/qQgGj6L.html
#2/ audiophile jazz webradio : ok
logs.volumio.org/volumio/sdgIHEJ.html
#3/ france musique la jazz : down
logs.volumio.org/volumio/LV34Huz.html
what to do ?
hi,
may be, the response could be in this log … but it’s not so clear for me …
Mar 13 07:21:16 volumio volumio[910]: ---------------------------- MPD announces system playlist update
Mar 13 07:21:16 volumio volumio[910]: info: Ignoring MPD Status Update
Mar 13 07:21:16 volumio volumio[910]: info: parsing response…
Mar 13 07:21:16 volumio volumio[910]: info: ControllerMpd::parseState
Mar 13 07:21:16 volumio volumio[910]: info: ControllerMpd::sendMpdCommand playlistinfo
Mar 13 07:21:16 volumio volumio[910]: info: ControllerMpd::sendMpdCommand load “http://direct.francemusique.fr/live/francemusiquelajazz-hifi.mp3”
Mar 13 07:21:16 volumio volumio[910]: info: sending command…
Mar 13 07:21:16 volumio volumio[910]: info: ------------------------------ 7ms
Mar 13 07:21:16 volumio volumio[910]: info: ControllerMpd::parseTrackInfo
Mar 13 07:21:16 volumio volumio[910]: info: ControllerMpd::pushError
Mar 13 07:21:16 volumio volumio[910]: info: message=Cannot read property ‘split’ of undefined, stack=TypeError: Cannot read property ‘split’ of undefined
Mar 13 07:21:16 volumio volumio[910]: at Promise._successFn (/volumio/app/plugins/music_service/mpd/index.js:291:54)
Mar 13 07:21:16 volumio volumio[910]: at nextTickCallback (/volumio/node_modules/kew/kew.js:47:28)
Mar 13 07:21:16 volumio volumio[910]: at _combinedTickCallback (internal/process/next_tick.js:131:7)
Mar 13 07:21:16 volumio volumio[910]: at process._tickCallback (internal/process/next_tick.js:180:9)
Mar 13 07:21:16 volumio volumio[910]: info: ------------------------------ 20ms
Mar 13 07:21:27 volumio volumio[910]: info: CoreCommandRouter::volumioGetState
Mar 13 07:21:27 volumio volumio[910]: info: CoreStateMachine::getState
Mar 13 07:21:27 volumio volumio[910]: info: CorePlayQueue::getTrack 1
Mar 13 07:21:27 volumio sudo[1630]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
Mar 13 07:21:27 volumio sudo[1630]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:21:27 volumio sudo[1630]: pam_unix(sudo:session): session closed for user root
Mar 13 07:21:27 volumio volumio[910]: info: CoreCommandRouter::volumioGetQueue
Mar 13 07:21:27 volumio volumio[910]: info: CoreStateMachine::getQueue
Mar 13 07:21:27 volumio volumio[910]: info: CorePlayQueue::getQueue
Mar 13 07:21:44 volumio volumio[910]: info: CALLMETHOD: system_controller system sendBugReport [object Object]
Mar 13 07:21:44 volumio volumio[910]: info: CoreCommandRouter::executeOnPlugin: system , sendBugReport
Mar 13 07:21:44 volumio sudo[1655]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig
Mar 13 07:21:44 volumio sudo[1655]: pam_unix(sudo:session): session opened for user root by (uid=0)
Mar 13 07:21:44 volumio sudo[1655]: pam_unix(sudo:session): session closed for user root
Mar 13 07:21:44 volumio sudo[1672]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl -p 7
Mar 13 07:21:44 volumio sudo[1672]: pam_unix(sudo:session): session opened for user root by (uid=0)
Any idea ?
