Some issues and a question
Pro’s:
  • Easy setup
  • Very clear and detailed sound
  • Excellent Graphical User Interface
    Issues:
  • Adding songs to playlist works ONLY for mp3’s and not for other extensions
  • After a fresh installation, songs added to the playlist are not seen in the playlist until the next boot
  • The playlist is out of sync with the reality, casing the player to crash
    The only solution is rebooting the system
  • You cannot browse on ARTISTS and SONGS
  • The browser is not working on iPad because the moving icons are not seen
    also the shift area (schuifbalk) on the right is not seen
  • The playback timer is not syncing with the real player
    It happens, that the player is not working while the timer continues
Questions:
  • Is there a way to restart MPD from the command line when the player apeears to hang ?? That would save a lot of restarts to get the player
    working
!! Keep going gents, I respect your initiative !!
Thank you for your feedbacks, if Volumio is what it is I must thank all the feedbacks I got…
To restart mpd if it hangs just do
sudo /etc/init.d/mpd restart
