[Solved] Why do tracks disappear from play list when I click on them
When ever I click on a track that I have added from the browse screen to the playlist it is deleted from the list and not played
hi!
you problably have the consume mode enabled : in the webUI in the playback page, just uncheck the dustbin.
Thanks, it was on , I was sure that I had turned it off, s it set on as a default somewhere?
Hi mjbedford,
You are right, there is an issue with Volumio 1.4. When you reboot, the consume mode is set back to “On”
