Good morning folks,
I just received my mini86. Which file system type do you recommend for the internal ssd I am about to use?
Kind regards
Bruno
Good morning folks,
Kind regards
Bruno
It’s probably best to use something native to the OS, so ext4 seems like a good choice. You can always check the file system for the OS partition and just use the same.
Though it should work without problems, I’d try to avoid NTFS in Linux.
