I´d just installed the 1.5 version on my CuBox i4. Pretty good work!!!
But I can´t see my CuBox in the network. With the 1.4 version I could see my device and the folders USB and WEBRADIO. So it was very easy for me to put on new audiofiles and webradios to my usb-HDD. I think I have to give rights to the folders, but how to do this?
I Think it is no general Problem.
I did the same, but all connections are working fine (Web Ui and HTML Interface)
Maybe you received another ip address for your cubox ?
No, I have static ip routing. HTML is working fine. If I start a search under Windows 7 to join volumio as a network share it will not find it. I tried both, the IP and the name volumio. Even a ping to the ip adress from cmd console is not possible. But under Firefox no problems at all.
I can confirm this problem on my device as well.
It worked well with Volumio 1.4, I could see the Volumio Samba shares in my network.
After I flashed Volumio 1.5, I cannot see any Volumio computer (and therefore no Samba shares Webradio, Ramplay, USB, NAS) in my network anymore.
There was no other change in my network, no changes on my router, no changes on my Windows computer.
Volumio 1.5
Cubox-i4
Windows 7 Home Premium x64
I have searched my Network using Windows Explorer, and also using Total Commander, no Volumio visible in the list of available computers.
I re-downloaded the Volumio 1.5 image, and re-flashed it, it did not help.
The file /etc/samba/smb.conf looks like this.
I tried to remove the character # in line # netbios name = Volumio, and restarted Volumio, but it did not help.
#======================= Global Settings =======================
[global]
workgroup = WORKGROUP
server string = Volumio Audio Player
dns proxy = no
log level = 0
syslog = 0
security = share
guest account = root
map to guest = bad user
#map untrusted to domain = yes
load printers = no
domain master = no
local master = no
preferred master = no
#======================= Share Definitions =======================
directory mask = 0775
create mask = 0775
[WebRadio]
comment = WebRadio Folder
path = /var/lib/mpd/music/WEBRADIO
read only = no
public = yes
follow symlinks = yes
wide links = yes
[Ramplay]
comment = Ramplay (256mb)
path = /run/shm
read only = no
public = yes
wide links = yes
[USB Music]
comment = USB stored music library
path = /var/lib/mpd/music/USB
read only = no
public = yes
wide links = yes
[NAS Music]
comment = NAS stored music library
path = /var/lib/mpd/music/NAS
read only = no
public = yes
wide links = yes
#[www]
# comment = Webserver root (/var/www)
# path = /var/www
# read only = no
# public = yes
# follow symlinks = yes
# wide links = yes
#[etc]
# comment = OS Config directory (/etc)
# path = /etc
# read only = no
# public = yes
# wide links = yes
#[mpd]
# comment = MPD directory (/var/lib/mpd/)
# path = /var/lib/mpd/
# read only = no
# public = yes
# wide links = yes
Please let me know if I can be of any help, like testing etc.
Thanks!
Pinging 192.168.1.10 with 32 bytes of data:
Reply from 192.168.1.10: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.10:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
I just checked my samba config file, its exactly the same, including the error:
security = share
But this isn’t the problem at hand (just creates an error message)
If it does not show this, but just a single line “pi 2737 2635 0 22:28 pts/1 00:00:00 grep nmbd” it’s safe to assume smbd and nmbd aren’t running. To start these do:
sudo service smbd start
sudo service nmbd start
And then try connecting to it using explorer and \volumio or \[ip of volumio]
The samba package is missing (even though the config files are there), developers are aware of this bug.
In the mean time, you can fix it by installing samba, e.g. via SSH:
Immediately after Samba was installed, Volumio shown up in the Windows Network Explorer.
Volumio is accessible in Windows Network also after I rebooted Volumio.
Hello, i have cubox-i4 pro with volumio 1.5 and i cannot see in mac finder the cube.
I tried to install samba by ssh with the following code
apt-get install samba
but it does not work and it has generated the following error message:
Err http://http.debian.net/debian/ jessie/main libhdb9-heimdal armhf 1.6~rc2+dfsg-8+b1
404 Not Found [IP: 212.25.8.232 80]
Err http://http.debian.net/debian/ jessie/main mysql-common all 5.5.40-1
Err http://http.debian.net/debian/ jessie/main libunistring0 armhf 0.9.3-5.2
404 Not Found [IP: 129.132.53.171 80]
Err http://http.debian.net/debian/ jessie/main libmysqlclient18 armhf 5.5.40-1
Err http://http.debian.net/debian/ jessie/main samba-dsdb-modules armhf 2:4.1.13+dfsg-2
Err http://http.debian.net/debian/ jessie/main libkdc2-heimdal armhf 1.6~rc2+dfsg-8+b1
Err http://http.debian.net/debian/ jessie/main samba armhf 2:4.1.13+dfsg-2
Err http://http.debian.net/debian/ jessie/main exim4-config all 4.84-3
Err http://http.debian.net/debian/ jessie/main exim4-base armhf 4.84-3
Err http://http.debian.net/debian/ jessie/main exim4-daemon-light armhf 4.84-3
Err http://http.debian.net/debian/ jessie/main exim4 all 4.84-3
Err http://http.debian.net/debian/ jessie/main samba-vfs-modules armhf 2:4.1.13+dfsg-2
Failed to fetch http://http.debian.net/debian/pool/main/libu/libunistring/libunistring0_0.9.3-5.2_armhf.deb 404 Not Found [IP: 129.132.53.171 80]
Failed to fetch http://http.debian.net/debian/pool/main/h/heimdal/libhdb9-heimdal_1.6~rc2+dfsg-8+b1_armhf.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/m/mysql-5.5/mysql-common_5.5.40-1_all.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/m/mysql-5.5/libmysqlclient18_5.5.40-1_armhf.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/s/samba/samba-dsdb-modules_4.1.13+dfsg-2_armhf.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/h/heimdal/libkdc2-heimdal_1.6~rc2+dfsg-8+b1_armhf.deb 404 Not Found [IP: 129.132.53.171 80]
Failed to fetch http://http.debian.net/debian/pool/main/s/samba/samba_4.1.13+dfsg-2_armhf.deb 404 Not Found [IP: 129.132.53.171 80]
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-config_4.84-3_all.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-base_4.84-3_armhf.deb 404 Not Found [IP: 129.132.53.171 80]
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4-daemon-light_4.84-3_armhf.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/e/exim4/exim4_4.84-3_all.deb 404 Not Found [IP: 212.25.8.232 80]
Failed to fetch http://http.debian.net/debian/pool/main/s/samba/samba-vfs-modules_4.1.13+dfsg-2_armhf.deb 404 Not Found [IP: 129.132.53.171 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
