I installed Volumio 1.4 on a Cubox-i2. When I mount my NAS (a D-Link ShareCenter with NFS), all goes fine, and the library is automatically updated, but after a while Volumio freezes and won’t boot anymore. I have to reformat the SD-Card (which, as I have determined, works fine), after which the same scenario happens again.
I recollect doing the mounting one time while being able to reboot Volumio. This is one time out of probably about 20.
I am happy to give you guys any information, but please tell me which because I am a rookie with Linux.
I use a generic supplied power supply. I use a generic class 10 SD-card. I can connect over ethernet, but the Cubox (or Volumio) freezes after a while. XBMC works perfectly, so the problem is not the hardware, but Volumio.
Tried a third good quality card now, and the problem persists in exactly the same way: Volumio freezes sooner or later and eventually won’t boot at all anymore. I’d like to stress that XBMC works fine on these cards, so the problem is not the hardware, but Volumio!
Recently, I made some adjustments in mijn modem because the employee of my provider and I tried to solve a problem. The current WiFi-settings of my modem are:
Channel: Auto
Speed: Auto
WPS: Not engaged
WMM: Engaged
Security: WPA2-PSK
WPA-encoding: TKIP+AES
I discovered there’s also lots of text on the HDMI output. It ends in a repeating message like: “eth0 attempt to connect to 255.255.255.255 port 67”, or something like that…
Yes, indeed. Maybe it is a faulty Cubox. I suspect the SD-card slot is not in order. I am going to swap the Cubox for another from the vendor. This should rule out the hardware a little
