[SOLVED]Volumio 2/ RASPBERRY 3 / BOOT FROM A USB
i have a question! I think Volumio 2 runs on Raspberian Jessi. So i would like to activate the greate new feature to boot from USB, but it doesn’ t work.
I use the Guid from raspberrypi.org raspberrypi.org/documentati … des/msd.md
I hope someone can help me.
THX
Sorry but Volumio won’t work with USB for a number of reasons
thx
Should be possible under Berryboot, though not tested.
Not officially supported though.
