Thanks chsims1! I ran the command you suggested. In the beginning of the output you can see the last two files that were successfully scanned. After that lots of errors followed.
b 06 19:17:22 pliniplayer mpd[986]: update: added USB/KINGSTON/Chopin - Nocturnes/Noctures/(Op. 62) Nocturne No. 2 in E Major.mp3
Feb 06 19:17:22 pliniplayer mpd[986]: update: added USB/KINGSTON/Chopin - Nocturnes/Noctures/(Op. 15) Nocturne No. 3 in G Minor.mp3
Feb 06 19:17:23 pliniplayer mpd[986]: mpg123: mpg123_getformat() failed: Message: I am done with this track.
Feb 06 19:17:23 pliniplayer mpd[986]: ffmpeg/mp3: Header missing
Feb 06 19:17:23 pliniplayer mpd[986]: ffmpeg/mp3: Could not find codec parameters (Audio: mp3, 0 channels, s16p)
Feb 06 19:17:23 pliniplayer mpd[986]: ffmpeg/mp3: Estimating duration from bitrate, this may be inaccurate
Feb 06 19:17:23 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: max_analyze_duration 5000000 reached
Feb 06 19:17:23 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: moov atom not found
Feb 06 19:17:24 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: max_analyze_duration 5000000 reached
Feb 06 19:17:24 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: moov atom not found
Feb 06 19:17:24 pliniplayer mpd[986]: mpg123: mpg123_getformat() failed: Message: I am done with this track.
Feb 06 19:17:24 pliniplayer mpd[986]: ffmpeg/mp3: Header missing
Feb 06 19:17:24 pliniplayer mpd[986]: ffmpeg/mp3: Could not find codec parameters (Audio: mp3, 0 channels, s16p)
Feb 06 19:17:24 pliniplayer mpd[986]: ffmpeg/mp3: Estimating duration from bitrate, this may be inaccurate
Feb 06 19:17:25 pliniplayer mpd[986]: ffmpeg/flac: Could not find codec parameters (Audio: flac, 0 channels)
Feb 06 19:17:25 pliniplayer mpd[986]: ffmpeg/flac: Estimating duration from bitrate, this may be inaccurate
Feb 06 19:17:25 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: max_analyze_duration 5000000 reached
Feb 06 19:17:25 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: moov atom not found
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: max_analyze_duration 5000000 reached
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: moov atom not found
Feb 06 19:17:26 pliniplayer mpd[986]: mpg123: mpg123_getformat() failed: Message: I am done with this track.
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/mp3: Header missing
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/mp3: Could not find codec parameters (Audio: mp3, 0 channels, s16p)
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/mp3: Estimating duration from bitrate, this may be inaccurate
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/flac: Could not find codec parameters (Audio: flac, 0 channels)
Feb 06 19:17:26 pliniplayer mpd[986]: ffmpeg/flac: Estimating duration from bitrate, this may be inaccurate
Feb 06 19:17:26 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Feb 06 19:17:28 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Feb 06 19:17:29 pliniplayer systemd[1]: mpd.service: main process exited, code=killed, status=11/SEGV
Feb 06 19:17:29 pliniplayer systemd[1]: Unit mpd.service entered failed state.
Feb 06 19:17:29 pliniplayer kernel: ieee80211 phy0: rt2800usb_txdone: Warning - Data pending for entry 1 in queue 2
Feb 06 19:17:29 pliniplayer systemd[1]: mpd.service holdoff time over, scheduling restart.
Feb 06 19:17:29 pliniplayer systemd[1]: Stopping Music Player Daemon...
Feb 06 19:17:29 pliniplayer systemd[1]: Starting Music Player Daemon...
Feb 06 19:17:29 pliniplayer systemd[1]: Started Music Player Daemon.
Feb 06 19:17:33 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Feb 06 19:17:33 pliniplayer volumio[861]: MPD error: Error: This socket has been ended by the other party
Feb 06 19:17:36 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Feb 06 19:17:36 pliniplayer volumio[861]: MPD error: Error: This socket has been ended by the other party
Feb 06 19:17:38 pliniplayer systemd-journal[175]: Suppressed 1210 messages from /system.slice/mpd.service
Feb 06 19:17:38 pliniplayer mpd[1267]: client: [1] opened from ::ffff:127.0.0.1:53128
Feb 06 19:17:38 pliniplayer mpd[1267]: client: [2] opened from ::ffff:127.0.0.1:53130
Feb 06 19:17:38 pliniplayer mpd[1267]: client: [3] opened from ::ffff:127.0.0.1:53132
Feb 06 19:17:38 pliniplayer volumio[861]: info:
Feb 06 19:17:40 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
Feb 06 19:17:41 pliniplayer mpd[1267]: client: [4] opened from ::ffff:127.0.0.1:53134
Feb 06 19:17:41 pliniplayer mpd[1267]: client: [5] opened from ::ffff:127.0.0.1:53136
Feb 06 19:17:41 pliniplayer mpd[1267]: client: [6] opened from ::ffff:127.0.0.1:53138
Feb 06 19:17:41 pliniplayer volumio[861]: info:
Feb 06 19:17:44 pliniplayer volumio[861]: info: CoreCommandRouter::executeOnPlugin: mpd , getMyCollectionStats
^Cvolumio@pliniplayer:~$
