[SOLVED] USB LCD 16x2. No track information
Dear all.
I purchased a USB LCD 16x2 to show track information. I followed this instructions carefully:
raspberrypiwiki.com/index.ph … _of_DAC%2B
The LCD starts and finishes ok, it shows message “Welcome to HIFI DAC!” and “Thanks for using HIFI DAC!”.
The message “Welcome to…” is always on, until I switch off Volumio (then shows “Thanks for using…”
When I play a song, nothing changes, continues “Welcome to…”, and no track information is showed.
I don’t know what could be wrong… Any help??
My configuration:
Raspberry Pi 1 B+
Hifiberry DAC+
Volumio 2.587
Thanks in advance!
Solved!!
solved by installing python3 and python3-pip, instead of python and python-pip
sudo apt install python3 sudo apt install python3-pip sudo apt install python-mpd sudo pip3 install mpdlcd
is it working with latest ver of volumio?
