[SOLVED] USB dac...understand
hi to everyone!
Using my raspberry pi 2 via usb…
  • Audioquest Dragonfly Black 1.5 (24/96)
  • PS Audio PerfectWave Dac MK2 (24/192)
When Raspy is starting up, the led color on Dragonfly is purple… 24/96…after a few seconds became green 16/44.
When Raspy is starting up, the panel of PS Audio PWDMk2 schow… 24/192…after a few seconds became green 16/44.
Anyone could tell me why?
thanks,
Arnaldo.
I assume that this happens when you start playing music/sound? (Which version of Volumio?)
Usually the devices start up in a default (highest) mode and when they are able to detect/sync they will switch to the correct mode. So it looks when the Pi I2S sends a 16/44 signal, your devices sync to this signal and report ok (green lights).
(My theorie from a distance :slight_smile: )
Verzonden vanaf mijn iPhone met Tapatalk
Thanks!
Arnaldo.
