Hardware: Audio Injector Octo on raspberry pi 3B +
Volumio 2.457 2018-09-17, no apt-get update
If I launch the Volumio2 web client, everything works well before installing the card (jack output).
Installing the card in Volumio with /etc/asound.conf and .asoundrc, then SSH:
Aplay -L: Ok
speaker-test -c 8: Ok, the 8 channels work
-> Playback Options (web page)
-Audio Output
-Output Device: audioinjector-octo-soundcard
-I2S DAC: Off
-Playback options
-DSD Playback Mode: DSD Direct
-DSD Auto Volume Level: Off
-Volume Normalization: Off
-Audio Buffer Size: 8MB
-Buffer Before Play: 10%
-Persistent Queue: On
-Volume Options
-Mixer Type: Hardware
-Mixer Control Name: DAC1
-Default Startup Volume: 50
-Max Volume Level: 100
-One Click Volume Steps: 10
-Volume Curve Mode: Natural
-MPD Clients Volume Control: Off
-Audio Resampling: Off
I can only listen to the webradios, not the shared music of Windows10 (which works with the configuration without the card => jack output).
If I try to play a shared music, I get an ECONNRESET error :
volumio@volumipi:~$ sudo journalctl -f
– Logs begin at Wed 2018-10-17 19:09:59 UTC. –
Oct 17 19:53:41 volumipi systemd[17975]: Starting Basic System.
Oct 17 19:53:41 volumipi systemd[17975]: Reached target Basic System.
Oct 17 19:53:41 volumipi systemd[17975]: Starting Default.
Oct 17 19:53:41 volumipi systemd[17975]: Reached target Default.
Oct 17 19:53:41 volumipi systemd[17975]: Startup finished in 17ms.
Oct 17 19:53:41 volumipi systemd[1]: Started User Manager for UID 1000.
Oct 17 19:53:41 volumipi sshd[17969]: lastlog_openseek: Couldn’t stat /var/log/lastlog: No such file or directory
Oct 17 19:53:52 volumipi sudo[18065]: volumio : TTY=pts/0 ; PWD=/home/volumio ; USER=root ; COMMAND=/bin/journalctl -f
Oct 17 19:53:52 volumipi sudo[18065]: pam_unix(sudo:session): session opened for user root by volumio(uid=0)
Oct 17 19:54:00 volumipi volumio[856]: info: CoreCommandRouter::volumioPlay
Oct 17 19:54:00 volumipi volumio[856]: UNSET VOLATILE
Oct 17 19:54:00 volumipi volumio[856]: info: CoreStateMachine::play index undefined
Oct 17 19:54:00 volumipi volumio[856]: info: CoreStateMachine::setConsumeUpdateService undefined
Oct 17 19:54:00 volumipi volumio[856]: info: CorePlayQueue::getTrack 0
Oct 17 19:54:00 volumipi volumio[856]: info: CoreStateMachine::startPlaybackTimer
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::clearAddPlayTracks NAS/CDs/Billy Paul/Billy Paul - Me and Mrs. Jones (Audio).flac
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::sendMpdCommand stop
Oct 17 19:54:00 volumipi volumio[856]: info: sending command…
Oct 17 19:54:00 volumipi volumio[856]: info: parsing response…
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::sendMpdCommand clear
Oct 17 19:54:00 volumipi volumio[856]: ---------------------------- MPD announces system playlist update
Oct 17 19:54:00 volumipi volumio[856]: info: Ignoring MPD Status Update
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::sendMpdCommand add “NAS/CDs/Billy Paul/Billy Paul - Me and Mrs. Jones (Audio).flac”
Oct 17 19:54:00 volumipi volumio[856]: info: ------------------------------ 7ms
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::sendMpdCommand play
Oct 17 19:54:00 volumipi volumio[856]: ---------------------------- MPD announces state update: player
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::getState
Oct 17 19:54:00 volumipi volumio[856]: info: ControllerMpd::sendMpdCommand status
Oct 17 19:54:00 volumipi kernel: bcm2835-i2s 3f203000.i2s: I2S SYNC error!
Oct 17 19:54:00 volumipi volumio[856]: error: MPD error: Error: read ECONNRESET
Oct 17 19:54:00 volumipi systemd[1]: mpd.service: main process exited, code=killed, status=11/SEGV
Oct 17 19:54:00 volumipi systemd[1]: Unit mpd.service entered failed state.
Oct 17 19:54:00 volumipi volumio[856]: error: Upnp client error: Error: This socket has been ended by the other party
Oct 17 19:54:05 volumipi systemd[1]: Starting Music Player Daemon…
Oct 17 19:54:06 volumipi systemd[1]: Started Music Player Daemon.
Oct 17 19:54:06 volumipi volumio[856]: info:
This happens also sometimes when launching a web radio (1 time out of 4).
Any idea ?
aseg
