hello,
just installed Volumio on RPI b+ with Hifiberry DAC+. All went well, no troubles.
Is it possible for Volumio to start playing a webradio on a given time? and stop playing after a specific time?
Would be great. Set up fo weekdays and weekend…
Thx.
jotak
2
I don’t know any built-in feature in volumio for this, but it can be easily done with the crontab and mpc commands.
=> Create a script file, for instance /home/pi/startRadio.sh
#!/bin/sh
mpc clear
mpc load WEBRADIO/myRadio.pls
mpc play
Do the same thing for a “stop” script, it will just contains the command:
#!/bin/sh
mpc stop
Then, all you have to do is manage those scripts through the crontab
Would be great to implement this in volumio…
when editing crontab, do i login ssh with volumio/volumio or pi/raspberry?
mbliek
6
Doesn’t matter. Just run:
Sudo crontab -e
