Installed latest version of volspotconnect2 v0.4.0 (also tried volspotconnect) using volumio 2. I was able to control Pi 3 using this plugin all day yesterday. Today, my devices show up in the devices list as “Can’t play this right now”. My devices will appear/disappear from the list normally, but cannot be selected. I’ve reinstalled the plugins, and rebooted, but nothing seems to work. I saved the output from the PI while enabling/disabling the plugin:
Aug 18 00:33:02 volumio-stax volumio[1004]: info: PLUGIN STOP: volspotconnect2
Aug 18 00:33:02 volumio-stax volumio[1004]: info: Killing Spotify-connect-web daemon
Aug 18 00:33:02 volumio-stax volumio[1004]: info: Disabling plugin volspotconnect2
Aug 18 00:33:02 volumio-stax volumio[1004]: info: Done.
Aug 18 00:33:02 volumio-stax sudo[4538]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl stop volspotconnect2.service
Aug 18 00:33:02 volumio-stax sudo[4538]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 18 00:33:02 volumio-stax systemd[1]: Stopping Volspotconnect2 Daemon…
Aug 18 00:33:02 volumio-stax systemd[1]: Stopped Volspotconnect2 Daemon.
Aug 18 00:33:02 volumio-stax sudo[4538]: pam_unix(sudo:session): session closed for user root
Aug 18 00:33:11 volumio-stax volumio[1004]: info: Enabling plugin volspotconnect2
Aug 18 00:33:11 volumio-stax volumio[1004]: info: Loading plugin “volspotconnect2”…
Aug 18 00:33:11 volumio-stax volumio[1004]: info: PLUGIN START: volspotconnect2
Aug 18 00:33:11 volumio-stax sudo[4557]: volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl start volspotconnect2.service
Aug 18 00:33:11 volumio-stax sudo[4557]: pam_unix(sudo:session): session opened for user root by (uid=0)
Aug 18 00:33:11 volumio-stax systemd[1]: Starting Volspotconnect2 Daemon…
Aug 18 00:33:11 volumio-stax systemd[1]: Started Volspotconnect2 Daemon.
Aug 18 00:33:11 volumio-stax sudo[4557]: pam_unix(sudo:session): session closed for user root
Aug 18 00:33:11 volumio-stax volumio[4562]: INFO:librespot: librespot ddfc28f (2017-08-04). Built on 2017-08-10. Build ID: Z3qO6N4b
Aug 18 00:33:11 volumio-stax volumio[1004]: info: Volspotconnect Daemon Started
Aug 18 00:33:11 volumio-stax volumio[1004]: info: Volspotconnect Started
Aug 18 00:33:11 volumio-stax volumio[1004]: info: Done.
Aug 18 00:33:11 volumio-stax volumio[4562]: WARN:mdns: Failed to register IPv6 receiver: Error { repr: Os { code: 19, message: “No such device” } }
SOLVED:
For some reason, Spotify Connect does not work when playing podcasts! When switching to an actual song, the devices were available again!
Myrulv
October 18, 2021, 3:32pm
4
I just experienced this from my iPhone 12 Pro!
Just spent over an hour restarting, reconnectiong every thing.
Thank you for the tip!
What version are you all using? Podcasts (well some of them) are supported in the newer versions…
I am experienced the same issue with 2 different Pi’s running 3.233.
A particular podcast would not play - Robert Plant Digging Deep.
On the Spotify app on android, “Can’t play this right now”
On iOS “Playback restricted”
No problem casting the podcast to other devices such as an AV receiver.
Other podcasts and music all ok.
A licensing restriction?
