Hello, I recently enabled Spotify support in Volumio. The sound drops out every now and then and I can’t figure out why. Nothing else significant is using my internet connection, and I don’t have this issue when playing local music. I documented the times that the issue is occuring (let’s call it a “blip”) and there is no discernable pattern to the moments of silence (which may last as little as a quarter second or up to a second or two). The blips also don’t appear to correspond to the times that spopd is downloading song parts from spotify (as reported by spopd.log). Here’s what I have so far:
https://docs.google.com/spreadsheets/d/1PL8W1K1uCoqHYxMiykPq9z4FS8vfoIIvjX6z6mTTOJs/edit#gid=0
I also disabled high quality audio to see if that helps, and it didn’t, although that may be because /etc/spopd.conf remains unchanged after modifying this setting (I assume it’s supposed to set high_bitrate = false per https://github.com/Schnouki/spop/blob/master/spopd.conf.sample).
Any idea what might be going wrong or how to troubleshoot further? I am using Volumio 1.5 on a Raspberry PI with a USB DAC (and yes I have forced USB 1.0 due to static issues with USB 2.0). Thank you!
