[Solved] SD Card Lifespan running 1.4?
Hi All,
If I leave the rpi on 24/7 and use it simply for airplay and webradio can I expect long life with my 8gig sd card?
Does Volumio need to write to the sd card a lot for this? What would be the hardest use of Volumio on the sd card?
Thanks,
Ben
It will last far more than your R-Pi.
Thanks Lag-na. I’ll start leaving the thing on 24/7.
