My rpib+ makers a click sound. About every 3-5 minutes. Strange.
Is this normal?
Volumio keeps on doing it job. Clicks’ is normale?
- Are you connected over lan or wlan?
- Which files do you play?
- Have you connected a DAC to your Raspberry?
i’m connected to my LAN.
playing webradio pls
i’m using a RPib+ with hifiberry DAC+.
but all works fine, just now and then a click.
do you also hear the clicks when you you are playing local music (from a usb stick for example)?
Click has gone after reboot. Don’t know how. But all is fine.
solved!
