Running V1.55 on a Raspberry Pi 2 and HiFiBerry DAC+, just installed everything and can only get airplay to work so I thought I would upgradeMPD accordnig to this but it does not work, missing packages. I am not a Linux newbie so I looked for the missing packages but cannot find them in the repo. Log:
root@volumio:~# dpkg -i mpd_0.19.9-2_armhf.deb
(Reading database … 36239 files and directories currently installed.)
Preparing to replace mpd 0.19.1-1 (using mpd_0.19.9-2_armhf.deb) …
[ ok ] Stopping Music Player Daemon: mpd.
Unpacking replacement mpd …
dpkg: dependency problems prevent configuration of mpd:
mpd depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11.4); however:
Package libavcodec56 is not installed.
Package libavcodec-extra-56 is not installed.
mpd depends on libavformat56 (>= 6:11~beta1); however:
Package libavformat56 is not installed.
mpd depends on libavutil54 (>= 6:11~beta1); however:
Package libavutil54 is not installed.
mpd depends on libmikmod3 (>= 3.3.3); however:
Package libmikmod3 is not installed.
mpd depends on libsystemd0; however:
Package libsystemd0 is not installed.
dpkg: error processing mpd (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
mpd
root@volumio:~#
