Hi
I have just changed my router (to Vodafone H500-s). I have Volumio on a Raspberry Pi Zero and on an Intel Atom netbook. After the change I can no longer play BBC radio streams. I can play other radio streams on Volumio, and I can play the BBC radio streams on other computers connected to the new router.
I also noticed that the ‘Check Updates’ button doesn’t work on either of the Volumio machines (I had previously used it on the Pi, so it used to work there).
In case it related to issues that had been fixed, I flashed the Raspberry Pi SD Card with Volumio 2.310, with the same results.
The router has an option called SecureDNS, which appears to block DNS lookups from alternative DNS servers. I have turned this off and Volumio is using the OpenDNS servers, but the results are the same.
Here are the logs from trying to playing a BBC Radio 1 stream that doesn’t work. In the GUI I see a red box that says “error: failed to decode http:…: got HTTP Status 0”. EDIT: The radio stream is: bbcmedia.ic.llnwd.net/stream/bbc … adio1_mf_p
2017-11-16T09:04:34.238Z - info: CoreCommandRouter::volumioAddQueueItems
2017-11-16T09:04:34.247Z - info: [1510823074240] CoreStateMachine::addQueueItems
2017-11-16T09:04:34.253Z - info: [1510823074248] CorePlayQueue::addQueueItems
2017-11-16T09:04:34.259Z - info: Adding Item to queue: http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p
2017-11-16T09:04:34.263Z - info: [1510823074261] CorePlayQueue::saveQueue
2017-11-16T09:04:34.276Z - info: CoreCommandRouter::volumioPushQueue
2017-11-16T09:04:34.283Z - info: [1510823074278] interfaceApi::pushQueue
2017-11-16T09:04:34.290Z - info: [1510823074285] InterfaceWebUI::pushQueue
2017-11-16T09:04:34.322Z - info: [1510823074316] CoreStateMachine::updateTrackBlock
2017-11-16T09:04:34.328Z - info: [1510823074323] CorePlayQueue::getTrackBlock
2017-11-16T09:04:34.336Z - info: CoreCommandRouter::volumioPlay
2017-11-16T09:04:34.343Z - info: [1510823074341] CoreStateMachine::play index 20
2017-11-16T09:04:34.346Z - info: [1510823074343] CoreStateMachine::setConsumeUpdateService undefined
2017-11-16T09:04:34.356Z - info: [1510823074347] CoreStateMachine::stop
2017-11-16T09:04:34.362Z - info: [1510823074357] CoreStateMachine::setConsumeUpdateService undefined
2017-11-16T09:04:34.367Z - info: [1510823074364] CoreStateMachine::play index undefined
2017-11-16T09:04:34.379Z - info: [1510823074367] CoreStateMachine::setConsumeUpdateService undefined
2017-11-16T09:04:34.383Z - info: [1510823074381] CorePlayQueue::getTrack 20
2017-11-16T09:04:34.386Z - info: [1510823074384] CoreStateMachine::startPlaybackTimer
2017-11-16T09:04:34.398Z - info: [1510823074387] CorePlayQueue::getTrack 20
2017-11-16T09:04:34.402Z - info: [1510823074400] ControllerWebradio::clearAddPlayTrack
2017-11-16T09:04:34.405Z - info: [1510823074403] ControllerMpd::sendMpdCommand stop
2017-11-16T09:04:34.431Z - info: [1510823074425] sending command...
2017-11-16T09:04:34.452Z - info: [1510823074446] parsing response...
2017-11-16T09:04:34.459Z - info: [1510823074453] ControllerMpd::sendMpdCommand clear
2017-11-16T09:04:34.462Z - info: [1510823074460] sending command...
2017-11-16T09:04:34.498Z - info:
[1510823074493] ---------------------------- MPD announces system state update
2017-11-16T09:04:34.502Z - info: Mpd Status Update: playlist
2017-11-16T09:04:34.505Z - info:
[1510823074503] ---------------------------- MPD announces state update
2017-11-16T09:04:34.521Z - info: [1510823074519] parsing response...
2017-11-16T09:04:34.525Z - info: [1510823074523] ControllerMpd::getState
2017-11-16T09:04:34.540Z - info: [1510823074526] ControllerMpd::sendMpdCommand status
2017-11-16T09:04:34.543Z - info: [1510823074541] ControllerMpd::sendMpdCommand load "http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p"
2017-11-16T09:04:34.556Z - info: [1510823074554] sending command...
2017-11-16T09:04:34.570Z - info: [1510823074564] sending command...
2017-11-16T09:04:34.586Z - info:
2017-11-16T09:04:34.603Z - info: [1510823074591] ------------------------------ 98ms
2017-11-16T09:04:34.610Z - info: [1510823074604] parsing response...
2017-11-16T09:04:34.618Z - info: [1510823074613] ControllerMpd::parseState
2017-11-16T09:04:34.625Z - info: [1510823074620] ControllerMpd::pushState
2017-11-16T09:04:34.632Z - info: CoreCommandRouter::servicePushState
2017-11-16T09:04:34.636Z - info: [1510823074632] CoreStateMachine::syncState
2017-11-16T09:04:34.641Z - info: [1510823074637] CorePlayQueue::getTrack 20
2017-11-16T09:04:34.643Z - info: [1510823074642] Received update from a service different from the one supposed to be playing music. Skipping notification.Current webradio Received mpd
2017-11-16T09:04:34.652Z - info: [1510823074648] ------------------------------ 148ms
2017-11-16T09:04:34.668Z - info: [1510823074664] ControllerMpd::sendMpdCommand add "http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p"
2017-11-16T09:04:34.673Z - info: [1510823074669] sending command...
2017-11-16T09:04:34.687Z - info:
[1510823074680] ---------------------------- MPD announces system state update
2017-11-16T09:04:34.692Z - info: Mpd Status Update: playlist
2017-11-16T09:04:34.694Z - info:
[1510823074692] ---------------------------- MPD announces state update
2017-11-16T09:04:34.700Z - info: [1510823074698] parsing response...
2017-11-16T09:04:34.703Z - info: [1510823074701] ControllerMpd::getState
2017-11-16T09:04:34.705Z - info: [1510823074704] ControllerMpd::sendMpdCommand status
2017-11-16T09:04:34.708Z - info: [1510823074706] CoreStateMachine::setConsumeUpdateService mpd
2017-11-16T09:04:34.720Z - info: [1510823074719] ControllerMpd::sendMpdCommand play
2017-11-16T09:04:34.731Z - info: [1510823074727] sending command...
2017-11-16T09:04:34.739Z - info: [1510823074734] sending command...
2017-11-16T09:04:34.775Z - info: [1510823074771] ------------------------------ 91ms
2017-11-16T09:04:34.780Z - info: [1510823074776] parsing response...
2017-11-16T09:04:34.785Z - info: [1510823074781] parsing response...
2017-11-16T09:04:34.790Z - info: [1510823074786] ControllerMpd::parseState
2017-11-16T09:04:34.796Z - info: [1510823074792] ControllerMpd::pushState
2017-11-16T09:04:34.800Z - info: CoreCommandRouter::servicePushState
2017-11-16T09:04:34.805Z - info: [1510823074801] CoreStateMachine::syncState
2017-11-16T09:04:34.810Z - info: [1510823074806] CorePlayQueue::getTrack 20
2017-11-16T09:04:34.815Z - info: STATE SERVICE {"status":"stop","position":null,"seek":null,"duration":null,"samplerate":null,"bitdepth":null,"channels":null,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":null,"artist":null,"album":null,"uri":null}
2017-11-16T09:04:34.820Z - info: CURRENT POSITION 20
2017-11-16T09:04:34.825Z - info: [1510823074821] CoreStateMachine::syncState stateService stop
2017-11-16T09:04:34.827Z - info: [1510823074825] CoreStateMachine::syncState currentStatus stop
2017-11-16T09:04:34.832Z - info: [1510823074827] CoreStateMachine::pushState
2017-11-16T09:04:34.834Z - info: [1510823074832] CoreStateMachine::getState
2017-11-16T09:04:34.836Z - info: CoreCommandRouter::volumioPushState
2017-11-16T09:04:34.838Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-11-16T09:04:34.854Z - info: [1510823074850] interfaceApi::pushState
2017-11-16T09:04:34.859Z - info: [1510823074855] InterfaceWebUI::pushState
2017-11-16T09:04:34.914Z - info: [1510823074910] No code
2017-11-16T09:04:34.919Z - info: [1510823074915] CoreStateMachine::pushState
2017-11-16T09:04:34.923Z - info: [1510823074919] CoreStateMachine::getState
2017-11-16T09:04:34.928Z - info: CoreCommandRouter::volumioPushState
2017-11-16T09:04:34.933Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-11-16T09:04:34.940Z - info: [1510823074936] interfaceApi::pushState
2017-11-16T09:04:34.945Z - info: [1510823074940] InterfaceWebUI::pushState
2017-11-16T09:04:35.007Z - info: [1510823075003] ------------------------------ 315ms
2017-11-16T09:04:35.035Z - info: Pushing Favourites {"service":"webradio","uri":"http://51.15.169.131:80/stream/2/","favourite":false}
2017-11-16T09:04:35.056Z - info: Pushing Favourites {"service":"webradio","uri":"http://51.15.169.131:80/stream/2/","favourite":false}
2017-11-16T09:04:35.072Z - info: Mpd Status Update: player
2017-11-16T09:04:35.078Z - info:
[1510823075073] ---------------------------- MPD announces state update
2017-11-16T09:04:35.086Z - info: [1510823075082] ControllerMpd::getState
2017-11-16T09:04:35.091Z - info: [1510823075087] ControllerMpd::sendMpdCommand status
2017-11-16T09:04:35.096Z - info: [1510823075092] sending command...
2017-11-16T09:04:35.159Z - info: [1510823075154] parsing response...
2017-11-16T09:04:35.177Z - info: [1510823075171] ControllerMpd::sendMpdCommand clearerror
2017-11-16T09:04:35.183Z - info: [1510823075179] sending command...
2017-11-16T09:04:35.190Z - info: [1510823075186] ControllerMpd::parseState
2017-11-16T09:04:35.194Z - info: [1510823075190] ControllerMpd::sendMpdCommand playlistinfo
2017-11-16T09:04:35.200Z - info: [1510823075196] sending command...
2017-11-16T09:04:35.228Z - info: [1510823075212] parsing response...
2017-11-16T09:04:35.238Z - info: [1510823075229] parsing response...
2017-11-16T09:04:35.249Z - info: [1510823075240] ControllerMpd::parseTrackInfo
2017-11-16T09:04:35.254Z - info: [1510823075250] ControllerMpd::pushState
2017-11-16T09:04:35.269Z - info: CoreCommandRouter::servicePushState
2017-11-16T09:04:35.273Z - info: [1510823075269] CoreStateMachine::syncState
2017-11-16T09:04:35.278Z - info: [1510823075274] CorePlayQueue::getTrack 20
2017-11-16T09:04:35.283Z - info: STATE SERVICE {"status":"stop","position":0,"seek":null,"duration":null,"samplerate":null,"bitdepth":null,"channels":null,"random":false,"updatedb":false,"repeat":false,"isStreaming":false,"title":"bbcmedia_radio1_mf_p","artist":null,"album":null,"uri":"http://bbcmedia.ic.llnwd.net/stream/bbcmedia_radio1_mf_p","trackType":"net/stream/bbcmedia_radio1_mf_p"}
2017-11-16T09:04:35.288Z - info: CURRENT POSITION 20
2017-11-16T09:04:35.298Z - info: [1510823075289] CoreStateMachine::syncState stateService stop
2017-11-16T09:04:35.303Z - info: [1510823075299] CoreStateMachine::syncState currentStatus stop
2017-11-16T09:04:35.305Z - info: [1510823075304] CoreStateMachine::pushState
2017-11-16T09:04:35.307Z - info: [1510823075306] CoreStateMachine::getState
2017-11-16T09:04:35.320Z - info: CoreCommandRouter::volumioPushState
2017-11-16T09:04:35.322Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-11-16T09:04:35.326Z - info: [1510823075324] interfaceApi::pushState
2017-11-16T09:04:35.348Z - info: [1510823075327] InterfaceWebUI::pushState
2017-11-16T09:04:35.430Z - info: [1510823075425] No code
2017-11-16T09:04:35.434Z - info: [1510823075430] CoreStateMachine::pushState
2017-11-16T09:04:35.439Z - info: [1510823075435] CoreStateMachine::getState
2017-11-16T09:04:35.444Z - info: CoreCommandRouter::volumioPushState
2017-11-16T09:04:35.450Z - info: CoreCommandRouter::executeOnPlugin: volumiodiscovery , saveDeviceInfo
2017-11-16T09:04:35.457Z - info: [1510823075453] interfaceApi::pushState
2017-11-16T09:04:35.462Z - info: [1510823075458] InterfaceWebUI::pushState
2017-11-16T09:04:35.525Z - info: [1510823075521] ------------------------------ 452ms
2017-11-16T09:04:35.587Z - info: Pushing Favourites {"service":"webradio","uri":"http://51.15.169.131:80/stream/2/","favourite":false}
2017-11-16T09:04:35.606Z - info: Pushing Favourites {"service":"webradio","uri":"http://51.15.169.131:80/stream/2/","favourite":false}
I tried to upload the log from the DEV page but this does not complete. Here is the relavent message from the logs
2017-11-16T09:12:04.616Z - info: CALLMETHOD: system_controller system sendBugReport [object Object]
2017-11-16T09:12:04.625Z - info: CoreCommandRouter::executeOnPlugin: system , sendBugReport
2017-11-16T09:12:09.698Z - info: Log sent successfully, reply: Cannot send bug report: Error: Command failed: /usr/bin/curl -X POST -H 'Content-Type: multipart/form-data' -F 'logFile=@/tmp/logondemand' -F desc='Sending log report, please wait' -F 'variant=volumio' 'http://logs.volumio.org:7171/logs/v1'
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (7) Failed to connect to logs.volumio.org port 7171: Connection refused
The update button is completely inactive at the moment (no logs), but I have previously seen it blink, and the log message was the same as I have seen in a couple of other posts
- info: Sending updateCheck to server
- info: Update Check error: [object Object]
Adrian.
