[Solved] Problem with radio station Trojka (ASX/WMA)
Hello!
I’m verry happy with Volumio. Stable, fast - great audio project.
But I have a small problem with radio - “Polskie Radio Trojka”.
I’m a big fan of this station and I still have to use FM to listen to it.
The stream is MS type - of course I have no problem to use it under Windows and Radiosure.
But how to do it with Volumio and RaspberryPi?
Streams:
Source 1
mms://stream.polskieradio.pl/program3_wma10
Source 2
polskieradio.pl/st/program3M.asx
Source 3
Source 4
Best regards,
Wojtek
Hi
From ssh console, create file (Trojka.pls) in folder /var/lib/mpd/music/WEBRADIO
Inside file put this:
[playlist]
numberofentries=1
File1=mmsh://stream.polskieradio.pl/program3?MSWMExt=.asf
Title1=PR Trojka
Or
[playlist]
numberofentries=1
File1=mms://stream.polskieradio.pl/program3
Title1=PR Trojka
Update WEBRADIO list. Use new station (it take few seconds, but works).
MMSH is MMS over HTTP.
greets,
Simi
Thanks!
It lasts dozen seconds… but it works indeed!! :slight_smile:
Anyway it strange - about 23 seconds to play - both pls.
w.p.
I am also interesting to listen PR Trojka, but I am completly fresh in Linux.
Can you explain me, step by step, how to create these changes, please.
Thanks.
Unzip file from attachment and copy file “PR Trojka.pls” to:
\volumio\WebRadio\
or
x.x.x.x = Volumio IP adress
\x.x.x.x\WebRadio\
Then update library.
PR Trojka.zip (228 Bytes)
Thanks!
It’s work.
Hi guys. Does not work for me. Do you need to wait 23 seconds for the radio to load or buffer?
Sent from my iPad using Tapatalk
Ok sorted it out. Just wait …it works
Hi, I use volumio primo device and have the same problem with polskie radio program 3.
I have in volumio primo in navigation menu place to write :
  1. name of the web station
  2. url address or pls or m3u file.
I have tried many time without success with this pls file:
1.Trojka
[playlist]
numberofentries=1
Title1=PR Trojka
This radio station is ones from the best in Poland and unfortunatelly there is not in the list of polish station createt by volumio team in volumio programm despite problems reported by others users - why?, who knows?
Best regards
Ryszard Trafny
