Sorry for reposting but I seem to have inadvertently deleted my original topic.
I was having problems saving, loading and modifying my conf and I have finally managed to make it work. So this is mostly to publish my code for a plugin that does nothing and to thank Stefan for the help and guidance.
The problem was mostly down to my ignorance of JavaScript and node.js, and a few typos here and there that made the process fail silently.
I basically had a self.logger.info(""); (should have been this.logger … or declare a self variable) in the getConfigurationFiles function that was failing so the config.json was never loaded so could not be displayed or saved.
I also modified the save function from:
self.config.set('pina', data['pina_setting']);
to
self.config.set('pina', data['pina_setting'][value']);
And I finally changed the getUIConfig fucntion to display the value and the label like so:
uiconf.sections[0].content[0].value.value = self.config.get('pina');
uiconf.sections[0].content[0].value.label = self.config.get('pina').toString();
For me this is solved and I can proceed to make the actual plugin.
However I am still not sure of whether I am handling things correctly as I do not seem to have the same code as other plugins developers.
config.json
"enabled": {
"type": "boolean",
"value": false
"pina": {
"type": "number",
"value": 2
"pinb": {
"type": "number",
"value": 3
"pinc": {
"type": "number",
"value": 4
UIConfig.json
"page": {
"label": "GPIO Rotary Encoder"
"sections": [
"id": "re_setup",
"element": "section",
"label": "Setup your Rotary Encoder PINs",
"icon": "fa-plug",
"onSave": { "type":"controller", "endpoint":"miscellanea/gpio-rotary", "method":"saveTriggers" },
"saveButton": {
"label": "Save",
"data": [
"pina_setting",
"pinb_setting",
"pinc_setting"
"content": [
"id": "pina_setting",
"element": "select",
"label": "GPIO for pin A",
"value": { "value": 2, "label": "2" },
"options": [
{ "value": 3, "label": "3" },
{ "value": 4, "label": "4" },
{ "value": 5, "label": "5" },
{ "value": 6, "label": "6" },
{ "value": 7, "label": "7" },
{ "value": 8, "label": "8" },
{ "value": 9, "label": "9" },
{ "value": 10, "label": "10" },
{ "value": 11, "label": "11" },
{ "value": 12, "label": "12" },
{ "value": 13, "label": "13" },
{ "value": 14, "label": "14" },
{ "value": 15, "label": "15" },
{ "value": 16, "label": "16" },
{ "value": 17, "label": "17" },
{ "value": 18, "label": "18" },
{ "value": 19, "label": "19" },
{ "value": 20, "label": "20" },
{ "value": 21, "label": "21" },
{ "value": 22, "label": "22" },
{ "value": 23, "label": "23" },
{ "value": 24, "label": "24" },
{ "value": 25, "label": "25" },
{ "value": 26, "label": "26" },
{ "value": 27, "label": "27" }
"id": "pinb_setting",
"label": "GPIO for pin B",
"value": { "value": 3, "label": "3" },
"options": [
"id": "pinc_setting",
"label": "GPIO for pin C",
"value": { "value": 4, "label": "4" },
"options": [
index.js
[code]‘use strict’;
var libQ = require(‘kew’);
//var fs = require(‘fs-extra’);
var Gpio = require(‘onoff’).Gpio;
var io = require(‘socket.io-client’);
var socket = io.connect(‘http://localhost:3000’);
module.exports = GPIORotary;
function GPIORotary(context) {
var self = this;
this.context = context;
this.commandRouter = this.context.coreCommand;
this.logger = this.context.logger;
this.configManager = this.context.configManager;
// demarrage de Volumio
GPIORotary.prototype.onVolumioStart = function() {
var self = this;
var configFile=self.commandRouter.pluginManager.getConfigurationFile(self.context,‘config.json’);
self.config = new (require('v-conf'))();
self.logger.info('GPIO-Rotary pre loadFile ' + configFile);
self.config.loadFile(configFile);
self.logger.info('GPIO-Rotary Initialized');
self.config.print();
// charge le fichier config.json
// c’est ce bout de bidule qui doit creer /data/configuration/miscellanea/gpio-rotary/config.json
// si il n’existe pas deja
// depuis /Volumio/app/pluginmanager.js
GPIORotary.prototype.getConfigurationFiles = function() {
this.logger.info(‘GPIO-Rotary Got config.json’);
return[‘config.json’];
// Demarrage du plugin
GPIORotary.prototype.onStart = function() {
var self = this;
var defer = libQ.defer();
self.logger.info('GPIO-Rotary Started');
defer.resolve();
return defer.promise;
// Arret du plugin
GPIORotary.prototype.onStop = function() {
var self = this;
self.logger.info('GPIO-Rotary Stopped');
defer.resolve();
// on utilise cette fonction lorsque on veut acceder a la configuration du plugin
GPIORotary.prototype.getUIConfig = function() {
var self = this;
var lang_code = 'en';
//self.logger.info('GPIO Rotary - getUIConfig - Start');
self.commandRouter.i18nJson(__dirname+'/i18n/strings_'+lang_code+'.json',
__dirname+'/i18n/strings_en.json',
__dirname +'/UIConfig.json')
.then(function(uiconf)
uiconf.sections[0].content[1].value.value = self.config.get('pinb');
uiconf.sections[0].content[1].value.label = self.config.get('pinb').toString();
uiconf.sections[0].content[2].value.value = self.config.get('pinc');
uiconf.sections[0].content[2].value.label = self.config.get('pinc').toString();
defer.resolve(uiconf);
.fail(function()
defer.reject(new Error());
// cette fonction est appelee depuis la page de conf pour enregistrer les parametres
GPIORotary.prototype.saveTriggers = function(data) {
var self = this;
//self.logger.info('GPIO Rotary: Print conf pre save.')
//self.config.print();
self.logger.info('GPIO Rotary - Saving PINs');
//self.config.set('pina', data.pina.value);
self.config.set('pina', data['pina_setting']['value']);
//self.logger.info('GPIO Rotary - Saved PIN A, value: ' + data.pina_setting.value);
//self.config.set('pinb', data.pinb.value);
self.config.set('pinb', data['pinb_setting']['value']);
//self.config.set('pinc', data.pinc.value);
self.config.set('pinc', data['pinc_setting']['value']);
self.logger.info('GPIO Rotary - PINs saved');
self.commandRouter.pushToastMessage('success',"GPIO Rotary", "Configuration saved");
defer.resolve();
//self.logger.info('GPIO Rotary: Print conf post save.')
[/code]
