Hi all.
I have been using Volumio for a few years, all was well on all Raspberry pi’s.
Now i can’t get the interface to show with the volumio app or typing in the ip to my address bar on my laptop.
This is only a problem with my pizero’s, (tried 3) all works perfectly when i use the same SD card in a pi3b+
the IP is recognised in a net scan and I can also ping it, but I can’t connect to show an interface.
This is version: 2.598 but I have also tried the 3 other previous versions, unfortunately with the same result.
Thank you for reading.
Sones
