I’m a long user of this wonderfull piece of software you made (back in raspyfi…)
I just upgraded from 1.4Beta (to get compatibility with my TP30 DAC) to 1.51 to see if the database can support my collection.
As usual I install my sdcard from scratch, clean install is better. I boot flawlessly with Ethernet plugged, get ssh connexion thru Ethernet IP like a breeze then go to the WebUI to fill wifi settings.
My Edimax : Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
connect to my wifi like a breeze, as I checked connection with ssh on the wifi adress without any problem, eventough wifi strength is abnormally weak.
I setup my nas path without any problems, then the Volumio name (for airplay).
Then I rebooted my Rasp using WebUI and disconnect Ethernet cable, and problem arise : Impossible to get webui nor ssh thru Wifi IP adress.
The only way to get response thru wifi is to plug in the ethernet cable when booting the Rapsberry, or when it booted only with wifi.
I have to say I’m stuck here and I don’t really understand the problem.
I upded Raspberry : sudo rpi-update, as my firmware isn’t up to date, but I’m not sure it’s the problem. (3.12.26+ to 3.12.34+)
Linux Douche 3.12.26+ #702 PREEMPT Wed Aug 6 17:43:49 BST 2014 armv6l GNU/Linux
root@Douche:~# sudo rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
*** Performing self-update
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 7811 100 7811 0 0 20232 0 --:--:-- --:--:-- --:--:-- 24409
*** Relaunching after update
*** Downloading specific firmware revision (this will take a few minutes)
100 168 0 168 0 0 337 0 --:--:-- --:--:-- --:--:-- 443
100 23.0M 100 23.0M 0 0 122k 0 0:03:12 0:03:12 --:--:-- 76551
*** Updating firmware
*** Updating kernel modules
*** depmod 3.12.34+
*** Updating VideoCore libraries
