Hi all,
Bought this cheap dongle from Monoprice due to its claimed Linux support.
goo.gl/O4Jo0H
The driver script seems to claim it’s a Realtek.
/RTL8188C_8192C_8192D_
Tried to see if it was recognized out of the box, no luck. Even ran the install shell script, and no luck there. Tried to set the network name/login in the GUI via ethernet, and then reboot with just the dongle and no luck.
Not really even sure if this this might not be defective? I thought I read somewhere these had Kernel support. Any thoughts would be appreciated.
wackid
September 25, 2014, 2:58pm
2
For me also no luck with the wifi dongle.
Even it is another one you’ve bought… driver is rtl8188C_8192C_usb_linux.
Please give us some hints to look for… i am not familiar with rpi… As i really need the cable one which it is running now.
Mine is exactly the same as in this post.
which-wifi-dongle-are-you-using-t1636.html
wackid
September 25, 2014, 5:29pm
3
HAHA… Mine is working…
I did two things…at the same time. So i dont exactly what did the trick.
I have updated the drivers by this tutorial.
raspberrypi.org/forums/viewt … 28&t=62371
I removed a line at network/interfaces.
learn.adafruit.com/adafruits-ra … cidentalis
I dont know the exactly phrase which i deleted.
But there was something like “Wlan power off”
I thought that was not a good command to have…
And set this command in the file “allow-hotplug wlan0” which was not present.
And now its working
Well &$*(%!!! Can’t tell you how much I have tried, and how much time I have spent on this.
Wackid’s solution worked for me.
Thanks!
On Cubox-i, the kernel seems to be version 3.0.35+ #1 . So this solution doesn’t work!
