SOLVED New router, no hotspot
Hi, I’ve just installed a new router, and therefore set a new wi-fi network , with a new password.
I rebooted my volumio Digione (heard the sound after a while), but I don’t see any hotspot appear in the wi-fi network panel of my control device. Tried to type 192.168.211.1, or volumio.local…nothing.
My Digione is on, but I can’t access it, nor listen to any music.
The WiFi works fine with all the other devices connected to it (pc, tablet, phones, tv)
Thanks for your help.
Solved
Connect the Digione via Ethernet cable, accessed to volumio and set new WiFi (network name & password)
ASAT, sorry
How did you figured it out? I’ve been giving question like 2 weeks on hos to do that till a friend of mine didn’t came and showed me http://www.router-reset.com . Now i owe him. There I found how to reset and set the router in the right way it has to work, it is a useful thing for sure.
