[Solved] New audiophonics es9023pi issue
Hi
I just began with this new dac, but it is not listed on the config. So I do not know how to handle it in volumio.
Thanks a lot for your help.
Hi!
You have the select hifiberry driver and software mixer (if you want to manage volume via volumio) via the webui. It should work with that :slight_smile:
Thanx for the help. I will try it. Regards
Hi
It work very well for the price it’s really nice. Thx for yhe help
