[Solved] My cubox-I1 wil not boot
20141129_195607.jpgHello,
I have problems getting volumio running on my cubox-i1.
Something goes wrong when it starts booting.
To test if my cubox is ok, i put the same way i did with the volumio image a openelec KODI image on my sd card and everything
worked smoothly. I will put a screen shot in an picture i made of the screen.This is the 1.2 image 1.4 did not work all so.
Hope some one can help me to get it work.
Thanks,
Roek
Hi, I’m about to release the new version for cubox-i… This will solve your issue…
Thanks Michelangelo ,i’m looking forward to install it.
:stuck_out_tongue:
