layums
1
Hi, i have 2 raspberry pi’s both with volumio. its that good. but both show with same ip.
how can i change ip on one
how to i add my own radio streams also. is it a simple case of putting stream addresses into a folder on the HHD that the music flacs are in?
thanks
Do you use a static IP on your PIs? Can you post the content of /etc/network/interfaces?
To use DHCP there must stand something like:
auto eth0
iface eth0 inet dhcp
Else it might use a static IP instead of using the DHCP service of your router.
PS
You could also make it static and define two different IP-addresses in your Routers IP-range for those two PIs.
Sent from my Nexus 7 using Tapatalk
layums
4
sorted all issues now. put in manually in the interface. and browsed to smb on mac
Good to here that. If you should ever need it again: You could get the interfaces with vim /etc/network/interfaces or instead of using vim with cat.
If you want to dive deeper into Linux I recommend you the Tutorial “Learn Linux the hard way”. nixsrv.com/llthw
It is well written and afterwards you get to know Linux really good.
