volumio wants everytime during boot process a login and pw.
Is there a way to boot volumio without manual login? Auto Login would be perfect
Greetings Ron_Muesli
you don’t need to login to use volumio. Just use a other device on the same network
Thank you for the quick reaction but what do you mean by other device?
To make this clear i have to login at the Raspi with external keyboard everytime volumio boots.
you don’t need a keyboard or a screen connected to your rpi. Just power it and connect from a other device (computer, smartphone) on the same network using the ip adress of your rpi with android device or volumio.local from a computer or Idevice
Okay got it! Thread can be closed it was my mistake
Thank you for your help
