I found out that the download link in the script was ok, but starting the script in volumio by pushing the button was giving always an empty archive, as above.
I have done another of, I don’t know how much, factory reset and new Images and found this posting …
lms-plugin-err-connection-refused-t11170.html
Follow these commands:
- Download the new script
wget -O install-lms.sh https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/install.sh
- Execute the script (fill in the passwd when prompted)
sudo sh install-lms.sh force
but that didn’t work too …
My next try was to push the button inside volumio, because it was a clean install … there was an error message but after reboot LMS was running
This for reference @Saiyato
volumio@volumio:~$ wget -O install-lms.sh https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/install.sh
converted 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/install.sh' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/install.sh' (UTF-8)
--2018-12-26 11:04:26-- https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/install.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.0.133, 151.101.64.133, 151.101.128.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.0.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 5280 (5.2K) [text/plain]
Saving to: 'install-lms.sh'
install-lms.sh 100%[=======================================================================================>] 5.16K --.-KB/s in 0.001s
2018-12-26 11:04:27 (8.84 MB/s) - 'install-lms.sh' saved [5280/5280]
volumio@volumio:~$ sudo sh install-lms.sh force
[sudo] password for volumio:
Installing LMS and its dependencies...
cpu: armv7l
Hit http://archive.volumio.org jessie InRelease
Hit http://archive.volumio.org jessie/main Sources
Hit http://archive.volumio.org jessie/contrib Sources
Hit http://archive.volumio.org jessie/non-free Sources
Hit http://archive.volumio.org jessie/rpi Sources
Hit http://archive.volumio.org jessie/main armhf Packages
Hit http://archive.volumio.org jessie/contrib armhf Packages
Hit http://archive.volumio.org jessie/non-free armhf Packages
Hit http://archive.volumio.org jessie/rpi armhf Packages
Hit http://archive.volumio.org jessie/ui Sources
Hit http://archive.volumio.org jessie/ui armhf Packages
Ign http://archive.volumio.org jessie/contrib Translation-en
Ign http://archive.volumio.org jessie/main Translation-en
Ign http://archive.volumio.org jessie/non-free Translation-en
Ign http://archive.volumio.org jessie/rpi Translation-en
Ign http://archive.volumio.org jessie/ui Translation-en
Reading package lists... Done
Downloading installation package...
converted 'http://downloads.slimdevices.com/LogitechMediaServer_v7.9.1/logitechmediaserver_7.9.1_arm.deb' (ANSI_X3.4-1968) -> 'http://downloads.slimdevices.com/LogitechMediaServer_v7.9.1/logitechmediaserver_7.9.1_arm.deb' (UTF-8)
--2018-12-26 11:05:49-- http://downloads.slimdevices.com/LogitechMediaServer_v7.9.1/logitechmediaserver_7.9.1_arm.deb
Resolving downloads.slimdevices.com (downloads.slimdevices.com)... 13.32.2.254, 13.32.2.31, 13.32.2.71, ...
Connecting to downloads.slimdevices.com (downloads.slimdevices.com)|13.32.2.254|:80... connected.
Length: 41508634 (40M) [text/plain]
Saving to: '/home/volumio/logitechmediaserver/logitechmediaserver_7.9.1_arm.deb'
/home/volumio/logitechmediaserver/logitec 100%[=======================================================================================>] 39.58M 5.78MB/s in 6.9s
2018-12-26 11:05:56 (5.73 MB/s) - '/home/volumio/logitechmediaserver/logitechmediaserver_7.9.1_arm.deb' saved [41508634/41508634]
Installing downloaded package
Selecting previously unselected package logitechmediaserver.
(Reading database ... 20919 files and directories currently installed.)
Preparing to unpack .../logitechmediaserver_7.9.1_arm.deb ...
Unpacking logitechmediaserver (7.9.1) ...
dpkg: dependency problems prevent configuration of logitechmediaserver:
logitechmediaserver depends on libio-socket-ssl-perl; however:
Package libio-socket-ssl-perl is not installed.
dpkg: error processing package logitechmediaserver (--install):
dependency problems - leaving unconfigured
Processing triggers for systemd (215-17+deb8u8) ...
Errors were encountered while processing:
logitechmediaserver
Building dependency tree
Reading state information... Done
unzip is already the newest version.
unzip set to manually installed.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
libio-socket-ssl-perl : Depends: libnet-ssleay-perl (>= 1.59) but it is not going to be installed
Recommends: libnet-libidn-perl but it is not going to be installed or
libnet-idn-encode-perl but it is not going to be installed or
liburi-perl but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Correcting dependencies... Done
The following extra packages will be installed:
libio-socket-ssl-perl libnet-libidn-perl libnet-ssleay-perl
The following NEW packages will be installed:
0 upgraded, 3 newly installed, 0 to remove and 24 not upgraded.
1 not fully installed or removed.
Need to get 449 kB of archives.
After this operation, 1491 kB of additional disk space will be used.
Get:1 http://archive.volumio.org/raspbian/ jessie/main libnet-ssleay-perl armhf 1.65-1+deb8u1 [259 kB]
Get:2 http://archive.volumio.org/raspbian/ jessie/main libio-socket-ssl-perl all 2.002-2+deb8u3 [172 kB]
Get:3 http://archive.volumio.org/raspbian/ jessie/main libnet-libidn-perl armhf 0.12.ds-2+b1 [17.6 kB]
Fetched 449 kB in 0s (663 kB/s)
debconf: delaying package configuration, since apt-utils is not installed
Selecting previously unselected package libnet-ssleay-perl.
(Reading database ... 24669 files and directories currently installed.)
Preparing to unpack .../libnet-ssleay-perl_1.65-1+deb8u1_armhf.deb ...
Unpacking libnet-ssleay-perl (1.65-1+deb8u1) ...
Selecting previously unselected package libio-socket-ssl-perl.
Preparing to unpack .../libio-socket-ssl-perl_2.002-2+deb8u3_all.deb ...
Unpacking libio-socket-ssl-perl (2.002-2+deb8u3) ...
Selecting previously unselected package libnet-libidn-perl.
Preparing to unpack .../libnet-libidn-perl_0.12.ds-2+b1_armhf.deb ...
Unpacking libnet-libidn-perl (0.12.ds-2+b1) ...
Setting up libnet-ssleay-perl (1.65-1+deb8u1) ...
Setting up libio-socket-ssl-perl (2.002-2+deb8u3) ...
Setting up logitechmediaserver (7.9.1) ...
Adding system user `squeezeboxserver' (UID 112) ...
Adding new user `squeezeboxserver' (UID 112) with group `nogroup' ...
Not creating home directory `/usr/share/squeezeboxserver'.
Setting up libnet-libidn-perl (0.12.ds-2+b1) ...
Linking CPAN to Latest
Fixing directory rights
mkdir: cannot create directory '/var/lib/squeezeboxserver': File exists
Adding the systemd unit
rm: cannot remove '/etc/systemd/system/logitechmediaserver.service': No such file or directory
converted 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/unit/logitechmediaserver.service' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/unit/logitechmediaserver.service' (UTF-8)
--2018-12-26 11:06:41-- https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/unit/logitechmediaserver.service
Length: 636 [text/plain]
Saving to: '/etc/systemd/system/logitechmediaserver.service'
/etc/systemd/system/logitechmediaserver.s 100%[=======================================================================================>] 636 --.-KB/s in 0s
2018-12-26 11:06:41 (2.11 MB/s) - '/etc/systemd/system/logitechmediaserver.service' saved [636/636]
Fixing CPAN Image::Scale...
converted 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_FIX_IMAGE.zip' (ANSI_X3.4-1968) -> 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_FIX_IMAGE.zip' (UTF-8)
--2018-12-26 11:06:41-- https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_FIX_IMAGE.zip
Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_FIX_IMAGE.zip [following]
converted 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_FIX_IMAGE.zip' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_FIX_IMAGE.zip' (UTF-8)
--2018-12-26 11:06:42-- https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_FIX_IMAGE.zip
Length: 166044 (162K) [application/zip]
Saving to: '/opt/CPAN_FIX_IMAGE.zip'
/opt/CPAN_FIX_IMAGE.zip 100%[=======================================================================================>] 162.15K --.-KB/s in 0.06s
2018-12-26 11:06:42 (2.55 MB/s) - '/opt/CPAN_FIX_IMAGE.zip' saved [166044/166044]
Archive: /opt/CPAN_FIX_IMAGE.zip
checkdir: cannot create extraction directory: /opt/CPAN/arm-linux-gnueabihf-thread-multi-64int
chmod: cannot access '/opt/CPAN/arm-linux-gnueabihf-thread-multi-64int/auto/Image/Scale/Scale.so': No such file or directory
CPAN image fix completed
Fixing CPAN DSD playback...
converted 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar' (ANSI_X3.4-1968) -> 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar' (UTF-8)
--2018-12-26 11:06:42-- https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar
Location: https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar [following]
converted 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar' (UTF-8)
--2018-12-26 11:06:43-- https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/CPAN_AUDIO_DSD_7.9.tar
Length: 194560 (190K) [application/octet-stream]
Saving to: '/opt/CPAN_AUDIO_DSD_7.9.tar'
/opt/CPAN_AUDIO_DSD_7.9.tar 100%[=======================================================================================>] 190.00K --.-KB/s in 0.08s
2018-12-26 11:06:43 (2.40 MB/s) - '/opt/CPAN_AUDIO_DSD_7.9.tar' saved [194560/194560]
converted 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/DSDPLAYER-BIN.zip' (ANSI_X3.4-1968) -> 'https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/DSDPLAYER-BIN.zip' (UTF-8)
--2018-12-26 11:06:43-- https://github.com/Saiyato/volumio-lms-plugin/raw/master/known_working_versions/DSDPLAYER-BIN.zip
Location: https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/DSDPLAYER-BIN.zip [following]
converted 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/DSDPLAYER-BIN.zip' (ANSI_X3.4-1968) -> 'https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/DSDPLAYER-BIN.zip' (UTF-8)
--2018-12-26 11:06:44-- https://raw.githubusercontent.com/Saiyato/volumio-lms-plugin/master/known_working_versions/DSDPLAYER-BIN.zip
Length: 84325 (82K) [application/zip]
Saving to: '/opt/DSDPLAYER-BIN.zip'
/opt/DSDPLAYER-BIN.zip 100%[=======================================================================================>] 82.35K --.-KB/s in 0.04s
2018-12-26 11:06:44 (2.06 MB/s) - '/opt/DSDPLAYER-BIN.zip' saved [84325/84325]
Archive: /opt/DSDPLAYER-BIN.zip
inflating: /usr/share/squeezeboxserver/Bin/arm-linux/libsoxr.so.0
inflating: /usr/share/squeezeboxserver/Bin/arm-linux/dsdplay
CPAN DSD playback fix completed
plugininstallend
