Initial impressions are Volumio is a huge step up from RaspyFi, good work.
I noticed at the foot of the System options there appears to be an option for Last.FM scrobbling (two input boxes with “This setting is the TCP port that is desired for the daemon to get assigned to.” below) but it’s not immediately obvious how this should be configured, any guidance?
I did look in the shell for a scrobbler type config file that could have needed tweaking but couldn’t find anything, nothing on the website either so I’m stumped.
Has anyone had any luck on the latest (or recent) versions of volumio?
I’ve tried the above steps with a fresh install of the latest image and I’ve not has any luck seeing anything appearing on my last.fm feed. It appears to be running, but I’m not sure where to check any logs other than this to see why I’m not getting any results.
Thanks in advance!
volumio@volumiozero:~$ systemctl status mpdscribble -l
● mpdscribble.service - Last.fm reporting client for mpd
Loaded: loaded (/lib/systemd/system/mpdscribble.service; enabled)
Active: active (running) since Wed 2017-07-05 14:12:35 UTC; 17min ago
Docs: man:mpdscribble(1)
Main PID: 17692 (mpdscribble)
CGroup: /system.slice/mpdscribble.service
└─17692 /usr/bin/mpdscribble --no-daemon
