Davy78
August 1, 2014, 2:36pm
1
I’ve got an issue i dont fully understand: i can connect to volumio from these devices/apps without problem:
ie in windows 8
Mpad on my ipad 4
But i cannot connct using:
chrome on windows 8
safari on ipad
I am mainly using the mpad app, but i would also like to have the other options. Any ideas?
joda2
August 1, 2014, 2:40pm
2
do you connect over the ip or with volumio.local ?
Davy78
August 1, 2014, 4:28pm
3
/facepalm
Ok, in IE in windows and mpad i am using the IP instead of the name … any idea why the name isnt working anymore? Im sure this has worked before, and i didnt change any network settings (i wouldnt know how)
joda2
August 1, 2014, 4:39pm
4
Are you sure that it worked?
You need to install Apple Bonjour to use volumio.local
Davy78
August 11, 2014, 5:31pm
5
I solved my connection issues. The problem was actually that my usb wifi dongle went to sleep after x hours.
Fix:
raspberrypi.stackexchange.com/qu … spend-mode
