Howto install build essential package on Volumio 1.4, when i try to install always says the repository it’s broken.
The following packages have unmet dependencies:
build-essential : Depends: gcc (>= 4:4.4.3) but it is not going to be installed
Depends: g++ (>= 4:4.4.3) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
