I tried to mount my share/Music folder from my Popcorn Hour A-200 to Volumio.
The A-200 is almost the same as a NAS.
At first I tried to enter the data by using the web-ui, but this did not work.
Then I followed the three steps from this topic (thanks Lechuck)
I used Putty
sudo apt-get update
sudo apt-get install cifs-utils
After I entered this rule with ip , username and password from the Popcorn Hour
sudo mount.cifs //192.168.0.90/public/Music /mnt/NAS —verbose -o user=USERNAME,password=PASSWORD,rw,iocharset=utf8,sec=ntlm
After finishing this three steps the NAS (A-200) had to update first and then everything was working like a charm.
After making a reboot on Volumio the playlist was still there but did not play anymore.
I tried to update the NAS again but then everything was gone.
Everything was the same as I started, no NAS
What to do now:
I entered the rule with username/pass again in Putty but now it did not work anymore.
I tried to mount the NAS again with the web-ui as Joep wrote on this topic:
problems-mounting-cifs-shares-t158.html?hilit=joep#p2264
Still no success.
I saw that Michelangelo wrote:
[i]“you can add the same string in /etc/fstab
That way your share will be mounted every reboot…”[/i]
Could this be my last hope?
But,
How do you add the same string in /etc/fstab???
Please be more clear!
I hope somebody can help me
