[Solved] How to delete playlist?
I added my whole USB drive as a playlist. 8000+ tracks later, trying to scroll through it crashes browsers. I can’t find a way to erase the playlist, and it persists between reboots! Help ;_;
Hi
You can connect by ssh to your device and run “mpc clear” :wink:
By the way, they are other way to do it. Volumio integrates a MPD daemon which is a very common music player in linux, so many client softwares exist to manage it. Under linux, you can install “GMPC” ( gmpclient.org/ )
If you want to control Volumio from an Android smartphone, you can also install MPDroid : play.google.com/store/apps/deta … ev.mpdroid
They are probably similar softwares for Windows, Iphone, etc.
Thanks! Trying out Theremin for OS X and also SSH.
