Even as in the default configuration ffmpeg support is enabled, while scanning my NAX, all *.m4h files are ignored (AAC without DRM). How could this be solved?
nano /etc/mpd.conf
And re enable ffmpeg support, save with ctrl+x . This is mpd’s bug, if it finds strange tags, it just halts and db update takes forever. Appears to be solved in new versions…
Hi did you find a solution to this?
As the original poster said, it looks like ffmpeg is already enabled with my installation… but it seems to ignore my m4a files.
“mpd -V” does show m4a listed against ffmpeg.
Thanks!
They are not appearing in the library section, but you should see 'em in browse mode… Let me know!
