I am planning to have multiple Volumio clients in my home and use bubble upnp app.
In the app Local render name shows ‘volumio’. How can change it to custom name like example ’ Living Room’.
if you use a raspberry, you can install volumio 1.41
in the system tab you can change your device name
Thanks. But, I already tried it. Changing name has not made any effect on DLNA name.
Dont know y. Can i make changes thru SSH? Where can i find the file to edit the name.
Agree this feature does not work for me in 1.41
You can edit etc/upmpdcli.conf, the parameter you need to edit is friendly name.
Kevin
Perfect…thanks for the help.
