Hi, everyone! Hope you’re having a nice life!
I’m having an issue with volumio finding the files/music stored in /data/INTERNAL. I didn’t format the disk and installed on a pc via settings → install on disk, and /data/INTERNAL is part of the SSD (120gb) space. I copied/paste the files using a file manager, and they’re there, however, in sources → my music, nothing shows and when click on update/re-scan, nothing happens. Is there a specific way to copy/store the files? Is there any specific format they should be? The files are -mp3s and .flac.
Below a screenshot that shows /data/INTERNAL containing 2.9gb of files:
Reading here Volumio doesn't find all my music. (SOLVED) - #6 by error45 I tried that suggestion “tail -f /var/log/mpd.log” and can see that “no read permissions” error appear for all the files when I click on rescan/update in my music → sources. What does that mean? How do I fix?
Thanks for the reply. You mean by typing in \volumio.local on the file manager? And how do I make sure files are owned by nobody? I just installed it and didn’t do anything special.
I use Linux, KDE Neon. Default name? volumio? Yeah, I didn’t change that. Actually, I forgot, but I uploaded the files with python3 -m uploadserver via web browser, then copy those files using ranger file manager I installed in volumio/debian to /data/INTERNAL. I think I’ll reinstall volumio and do as you say. Thanks!
