[solved] Favourite menu is empty
Hi, I use volumio with a zero and a dac to have netradio and Spotify in my garden.
It works fine. But if I chose the heart symbol of a playing radio station it shows “added to favourites” but the list of the volumio does not contain any entry.
What do I wrong? Is this function only for local stored music like USB stick?
Thanks for your help.
Best regards
Tobbes
I think it adds it to ‘radio favourites’, which is different from ‘favourites’
Thanks to chsims1,
I looked into the radio favourites and there are all my stations …
