sudo mkdir /mnt/NAS/FRITZ
then try the mount command as shown above
… I already did and its visible under Windows network
When I then run
mount -t cifs -o username=volumio,password=volumio,ro,dir_mode=0777,file_mode=0666,iocharset=utf8,noauto //192.168.6.101/FRITZ.NAS/TOSHIBA-ExternalUSB3-0-01/Musik_FLAC
I get
mount: can't find //192.168.6.101/FRITZ.NAS/TOSHIBA-ExternalUSB3-0-01/Musik_FLAC in /etc/fstab
You are still using the original path, which we already know doesn’t work/is incorrect (you are also using an incorrect syntax). Smbclient indicates the share on your NAS is ‘7490’
Try from the UI to add the share path as ‘7490’ or ‘7490/TOSHIBA-ExternalUSB3-0-01/Musik_FLAC’ (use 192.168.6.101 as IP address)
As a note, when you edit earlier posts can you please make it clear what has been edited, otherwise the clarity of the thread may become distorted.
@chsims1
Good morning and thanks a lot! When I came home from a Jazz openair last night I tried:
'7490/TOSHIBA-ExternalUSB3-0-01/Musik_FLAC' (use 192.168.6.101 as IP address)
and it works.
Now - as I know - it’s easy and obvious. I must have smoked the wrong kind off stuff :mrgreen: .
I want to learn so let me ask what do you mean with
… You are definitely right! I pledge improvement.
The mount command you posted:
as well as using the wrong share path didn’t have the correct syntax … you need to specify where the share is to be mounted, so:
sudo mount -t cifs -o /mnt/NAS/FRITZ
Anyway, I’m glad that you finally got things sorted, & perhaps learnt a little on the journey. ![]()
… you are never too old to … ![]()
I have the same problem mounting NAS on volumio. The correct path is FRITZ.NAS/TOSHIBA_EXT/Fidelity/
Do you use username and pass? Do you use ver=1.0 ?
The latest FRITZ!OS version 07.20 (from July 2020) is disabling SMBv1 (vers=1.0) for security reasons. If you still need it, you have manually enable it in the Fritz!OS settings or better set now “vers=3.0” to your SMB options of Volumio
